Can not edit slab
Could you please tell me why I cannot edit "Slab" element (see attached file "Inactive Slab"?
I need it to be like the attached file "Active Slab".
Aysel.
Podolsky
Ace
What I can see here - two screenshots. One from Russian ArchiCAD, I guess version before 24, and second from English ArchiCAD 24.
The first (active, Russian) says - it's load-bearing element (конструктивная функция - несущий элемент).
Second says that structural load is undefined.
Also in the second screenshot FLOOR PLAN AND SECTION and MODEL (ОТОБРАЖЕНИЕ НА ПЛАНЕ И В РАЗРЕЗЕ и МОДЕЛЬ) tabs are hidden. It happens when ArchiCAD work environment is switched to "Structural Engineering Basic Profile". Switch to Architectural Basic, Architectural of Structural Engineer profile, to see these tabs.
Podolsky
Ace
Thank you for your help @Podolsky, it worked out!
KR,
Aysel.
