2008-08-20
09:19 PM
2023-05-23
03:09 PM
Rubia Torres
2008-08-20 09:39 PM
2008-08-20 10:05 PM
new2archicad wrote:Can... open. Worms... everywhere!
1. is archicad better than revit?
2. does archicad have cad capabilities for custom design such as millwork, stone, etc.?
2008-08-22 01:11 AM
"Peter Devlin" wrote:
Gable roofs are very simple to make.
Thank you for your quick and responsive reply to my question, I was pleasantly surprised.
I guess I should have mentioned that i am using pc not mac, (command-click, is that mac for control-click?) Anyway all goes well up to the point
below;
Select one roof by selecting the ridge edge of one roof...
I tried everything a dozen times to the letter and ac will not stretch object, only move it. I tried edit/stretch and some other things, even in 3d, all to no avail.
I would suspect the installation is corrupted except everything else works fine, including the tutorials.
I don't understand why such a simple and oft-used task would be so complicated, (even when it works), in ac when less robust design programs perform this with a few simple clicks. Am I missing something?
If you have any suggestions in this regard and the time to respond, I would appreciate it. Also I would appreciate your honest opinion, if you have one, as to the limitations of ac in the matter of use for high-end single family residential and multi-use residential design. I am all too aware that all programs have some quirks and limitations but this has really got me bummed-out, as it is a function that I use x times daily.
Hope I have not bored you too much...
Thank you very much
2008-08-22 01:35 AM
2008-08-22 01:59 AM
2008-08-23 05:28 PM
new2archicad wrote:What you did not do is learn how to do it.
i may be dumbest person on planet but can't get gable roof created no matter what i do.
2008-08-23 05:31 PM
new2archicad wrote:My dad is stronger than your dad.
new2archicad wrote:No it does not. No software does. Unless you know how to do it in a given software.
2008-08-25 02:57 AM
new2archicad wrote:I think the more serious answer is more similar to the answer to
1. is archicad better than revit? .
2008-08-25 04:49 AM
TomWaltz wrote:Except Labels,Keynotes and Revisions where Revit wins handsdownnew2archicad wrote:Archicad better at Documentation.
