Can't modify speed in explore on MacBook Pro
julienK
Up until archicad 21 to increase the traveling speed in explore mode I use the secondary button " . " because the + doesn't work on a laptop keyboard.
I downloaded 22 to try it out and see of a bug I had reported had been fixe ( it has ) but this new one is problematic for me.
Even though in the explore instructions the dot is still listed alongside the + to increase speed it won't work on my laptop.
I normally use the French version of archicad but downloaded the INT version of 22 because I was impatient to try it out.
Could this be the reason the key won't work ? using an INT version with a French keyboard ? Has anyone else having this problem ? Maybe I'll wait ton see if it still the case when 22 FRA is released.
Daniel Kovacs
I tried it with my macbook, and it seems to be working fine for me. Have you managed to find out what the problem was?
Have you tried ARCHICAD 21 INT? (if it is bad as well, then it might be because of the language version indeed).
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
julienK
It works fine with the french version of archicad.
Probably just an incompatibility between the int version of AC and french keyboards.
