4 weeks ago
I would like to ask if it is possible to make the cover fill of this ramp object non-transparent. Currently, the fill appears transparent, and I would like it to display as a solid cover fill in the floor plan. How can I achieve this
Operating system used: Windows 10
Solved! Go to Solution.
4 weeks ago
- last edited
4 weeks ago
Hi. It is possible to make the fill opaque.
Also, you might want to make sure you don't have a graphic override on that changes that setting.
4 weeks ago
if it is transparent, but the fill is set to have an opaque fill type/pen number, then it could be a graphic override or renovation filter override changing the cover fill or drafting fill to be transparent.
4 weeks ago
- last edited
4 weeks ago
4 weeks ago
- last edited
4 weeks ago
which library part is that?
in this object, there are settings for fill type, and fill foreground/background:
(Edit: seeing this is likely the same object CosminF shared)
4 weeks ago
