mrsneuna
Can the Ramp Object Cover Fill Be Made Non-Transparent?
I would like to ask if it is possible to make the cover fill of this ramp object non-transparent. Currently, the fill appears transparent, and I would like it to display as a solid cover fill in the floor plan. How can I achieve this
Operating system used: Windows 10
2 Solutions
CosminF
Hi. It is possible to make the fill opaque.
Also, you might want to make sure you don't have a graphic override on that changes that setting.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
Patrick M
if it is transparent, but the fill is set to have an opaque fill type/pen number, then it could be a graphic override or renovation filter override changing the cover fill or drafting fill to be transparent.
Go to post
3 Replies 3
CosminF
Patrick M
which library part is that?
in this object, there are settings for fill type, and fill foreground/background: 
(Edit: seeing this is likely the same object CosminF shared)
Patrick M
