Cannot see walls on Ground Floor
Hi Guys
I am creating a building on ArchiCAD 17, on my Mac OS X 10.9.1
I am getting a problem where I can see the roof on ground floor, and I cannot see my walls, unless I select my walls. Please see screenshots below!
1st Picture
As you can see on the right, I am in the ground floor, but I can only see the roof, no walls.
2nd Picture
As you can see, you can still see the roof, but I have selected my walls.
[/img]
Does anyone know a solution for this?
Thanks in advance!
Joe
4 Replies 4
Joe,
turn of cover fill to the roof and you should be able to see the walls, I usually have a new storey for the roof and have it display dashed the storey below.
Regards,
Scott
sboydturner wrote:
Joe,
Regards,
Scott
Thanks for your reply!
I am new to ArchiCAD, how do I turn off the cover fill to the roof?
Thanks
Joe
schagemann
Select the roof, open the Roof Selection Settings (CMD + S) then under the 'Floor Plan and Section' section choose to disable cover fills.
Arguably, however you should have your roof on a separate Story - you might find the following tutorials useful… http://goo.gl/58ngz5
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
Thanks! That worked!
Also, my roof is on a separate Story. It is on roof, not ground floor.
Thanks Again
