trk001:
This is how I would do it:
1. Select the Door.
2. Activate the Drag command
3. Activate the Snap Point Constraint (Snap Points is set to Half)
4. Click on the two grid lines you want the Door centered on (click anywhere on the grid lines, the Door will stay in the Wall)
David
