Centering a pocket door in Archicad 17
mukster
I'm having a little trouble centering the pocket door in the wall. Using Archicad 17 on a Mac platform
The answer may well depend on what pocket door object you are using.
I'd be guessing you need to set a 0 (zero) reveal depth so the frame sits flush with the face of the wall and then specify your frame depth to be the same as the wall thickness.
Stress Co_
One thing to add to Barry's answer.
Be sure that "Centered Leaf" is checked in the door frame settings.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Aaron Bourgoin
If you mean centring the door opening along the length of the wall, The "Special Snap Constraint" can centre anything on anything else. It's found on the "Drafting Aids" toolbar.
Indispensable tool. used in conjunction with "Special Snap Options" settings.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
