Change zone boundary outline method
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2012-01-04
06:52 PM
‎2023-05-24
01:00 PM
Rubia Torres
‎2012-01-04
06:52 PM
Thanks.
Tom.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-05 09:04 AM
‎2012-01-05
09:04 AM
Yep
If the walls are correctly joined, then just switch them to automatic and update.
If not, and they have to stay manual, select one by one and use polygon editing tools. You know how to edit polygons, don't you?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-05 07:52 PM
‎2012-01-05
07:52 PM
Tried the switch to automatic and update, but it had no effect. I can edit the polygons, but it is time consuming for the number of zones I have. Am looking for a way to let the computer do it all at once.
Tom
Tom
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-06 10:09 AM
‎2012-01-06
10:09 AM
Tom wrote:Select all the zones at the same time and then change them to automatic. Check the areas after the update; if some walls are not joined properly, some zones might "leak". If your zone backgrounds are off, you will see the polygons only when you select them.
Tom
Djordje
HP Omen
HP Omen
