Tom Krowka
Change zone boundary outline method
Am looking for a way to change zone boundary outline. I have some zones that were input via manual click at the outline. I would like to change them to centerline of the walls. Any easy way to do it automatically. I have lots of them.
Thanks.
Tom.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
3 Replies 3
Djordje
Yep
If the walls are correctly joined, then just switch them to automatic and update.
If not, and they have to stay manual, select one by one and use polygon editing tools. You know how to edit polygons, don't you?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Tom Krowka
Tried the switch to automatic and update, but it had no effect. I can edit the polygons, but it is time consuming for the number of zones I have. Am looking for a way to let the computer do it all at once.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
Djordje
Tom
Select all the zones at the same time and then change them to automatic. Check the areas after the update; if some walls are not joined properly, some zones might "leak". If your zone backgrounds are off, you will see the polygons only when you select them.
Djordje
HP Omen
