2024 Technology Preview Program
Changing Archicad objects default background color
User1
When I insert an object from the Archicad library, the bacround color is always either black or grey and I cannot change it. I want to have no background on the objects and just the outlines. I would like to know how to change this?
Rajesh Patil
Check the pen number used for "background" of library item , change it to suitable one as needed.
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
5 REPLIES 5
Rajesh Patil
Rajesh Patil
Hello User1,
I guess you have modified your pen set and I agree with Rajesh.
And you are able to do a graphic override to get your aim easily too !
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
runxel
Legend
This is actually an option inside the Archicad settings.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
That is actually talking about the option to automatically invert the pen colour (lines or fills) if it is the same as the background colour of the screen (i.e. white on white background will change the pen colour so you can see it).
That is not exactly what the original poster was referring to (I don't think) - but it is a good tip to remember.
Yeah true, Barry. I was hasty and somehow only seeing the grey table, not the black bed.
If this option is turned on, every object with a white fill on a white background would become grey (and not some grey and some black...)
