Changing Font in the Navigator AND interface
How can i change the font in the navigator to support greek fonts?
I get scrambled fonts on all the program tabs..
Any suggestion? Where does the font change?
8 REPLIES 8
MarinRacic
Same here. I need Central European fonts to show there...
Is AC9 unicode? Karl mentioned it a while ago in some other thread, but I don't have ac9 so I can't verify.
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
In some dialog boxes i see greek characters in some not.
In the navigator library items open file dialog box and some more
i see scrambled output.
I wonder the localised versions do a recompilation? I doubt that.
The new configurable interface does not let you choose the font??
Does anyone know?
Here is the answer
For the pc at least.
Regedit.
HKEY_CURRENT_USER
Software
Graphistoft
Archicad (8-9 .....)
Font Description
FOnt Script Code ..... 161 for GREEK
For cyrilic i dont know but try changing that value.
Hope that helps
Gorazd
For CE fonts you type in 238. Sorry Marin, I dont know the soluton for Mac yet, but I will try to find out. And NO, ArchiCAD 9 is not unicode, as far I know.
I think these are the codes you can use:
! Available character sets on Windows and Macintosh platforms
! 0 = Western European (ANSI_CHARSET)
! 128 = Japanese (SHIFTJIS_CHARSET)
! 129 = Korean (HANGEUL_CHARSET)
! 134 = Chinese [PRC, Singapore] (GB2312_CHARSET)
! 136 = Chinese [Taiwan, Hong Kong] (CHINESEBIG5_CHARSET)
! 177 = Hebrew (HEBREW_CHARSET)
! 178 = Arabic (ARABIC_CHARSET)
! 161 = Greek (GREEK_CHARSET)
! 162 = Turkish (TURKISH_CHARSET)
! 222 = Thai (THAI_CHARSET)
! 238 = Eastern European (EASTEUROPE_CHARSET)
! 204 = Russian (RUSSIAN_CHARSET)
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
Dalius
How to change Font Description Code on Mac?
Dalius Regelskis
Archicad user since version 6.0
https://archicad-pamokos.lt
For Cyrillic the code is: 204.
For Ac10 this is the place you put the code:
And this is for the shortcut commands. Change the value to "1".
Dalius
And how about Mac?
Dalius Regelskis
