Collinear walls
Hello everybody
Suppose I have to collinear walls. One wall is made of bricks and the other one is made of concrete. In plan view I want to separate them with a line. The only way I found to do this is by inverting concrete wall’s reference line. Is there any other way without doing that? See attached jpg.
Thank you in advance.
10 Replies 10
Petros Ioannou
ooops ! just saw that this was what matthew suggested!
Anyway to add something new, you can use Composites for the masonry wall and cover the corner column with the veneer of your wall (two walls overlaping on that area .... )
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
