Colors inverted. The solution?
I just installed my educational archicad 14. And the colors are inverted. The background is set to be white but appears black. all black lines are gray. the pointer is black with white contour.
I tried everything. I read the guide, searched the web and no answer. how do i fix this???
Use
CTRL-ALT-N
or
File\New\New & Reset All menu command (press ALT key while choosing this command for this option to appear).
This will load all default project settings.
it was my video card. if anyone else has this problem, check your video card options.
