Zendrix
Column (complex profile) finish/veneer
Hi!
I have a pilar that is a bit skewed so i had to use the "complex profile" option, but now i see there is no "finish" or "veneer" option for the complex profile.
How would i go about to have a finish on it?
I had to use that complex profile on the story below without finish. Do i have com make a copy of that same profile but add the 2cm plaster finish on the complex profile drawing itself?
Thanks
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
2 Solutions
cuba
You will have to draw the finish yourself in the complex profile. Basically, you don't need a complex profile in your situation; your shape is rectangular, if you place the column as a “normal” column, you can turn on the finish.
Apple M1 Max 32 GB
Latest AC
Go to post
A complex profile column is like a complex profile wall.
The fills (building materials) you use to create it can be any shape and in any position.
So you can create a complex profile column with a veneer skin that is any shape you want.
The veneer button will not work with complex profiles.
You have to create the veneer in the profile itself.
Go to post
5 Replies 5
cuba
Apple M1 Max 32 GB
Latest AC
Zendrix
Hi!
My pillar is not rectangular, it is skewed, as i said in the the main text (no 90⁰ degrees between sides).
I will then have to recreate that pilar from below and add manually the plaster.
Thanks!
Zendrix
I replied on my cellphone but it didnt get posted. The element is skewed, as i said in the text above, there are no 90º degrees angles between any sides on the column. So i guess i will have to duplicate that profile and add the plaster manually to it.
Thanks,
For some reason it got quarantined as spam.
The post has now been released.
