2012-04-1112:14 PM - last edited on 2023-05-2612:49 PM by Rubia Torres
2012-04-1112:14 PM
I have problem with my column.
What I did is changed the default column material from "Surf-Poured Concrete" to "Paint-01", as you can see it:
And while working in Archicad 3d mode, everything seems to be fine, and as you can see the column is white now:
But when I render it, it still appears as it has "Surf-Poured Concrete" material on it:
Why is that?
Also as you can see it from the first picture, when ever I select the column, it appears with it's default material "Surf-Poured Concrete" even though I changed it to "Paint-01".
