Complex Profile Fills have no texture any more
Gus
Somehow when I edit my complex profile walls I can only see the outlines of the fills. My vectorial hatching is turned on in my onscreen view options, but still no fills to be seen. Can anyone think of why I cannot see fills anymore on my complex profile walls when I am editing them?
Gus
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
3D-hatching is a material option. Did you change face material of profile or control it in Material Editor?
Gus
Just solved my own problem.
The solution is to go to Options/Model View Options, and select a different view options setting. I should have thought of this. It does make me think that in the "View" menu "Model View Options" should be placed just below or just above "On-Screen View Options." This is because one would intuitively go to the "View" menu in order to find the "Model 'View' Options," simply because the word "view" is in the menu and in the "Model 'View' Options Name."
Madison WI
