Complex Profile Wall Cleanup Problem
See attached screenshots. I've got a pretty simple wood stud wall as a complex profile, and when I intersect them at the corners, it leaves a gap at the bottom. What gives?
10 REPLIES 10
Intersection
Note: when I delete the basement CP wall below, the intersection clears up. attached is a section view of the walls.
showing the walls cut back
intersected
messy intersection carries through from bottom to top.
Any ideas?
The wall, because of the height, was showing on the basement plan and thus trying to heal itself into the basement walls as well, which was causing the problem. SORRY!
RandyC
Was that a monologue ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Yes I had quite the conversation with myself!
Hi Steven
Did you try to change the axis position on wall?
Sometime it helps.
This example very complicated. I suggest to make it simpler and test before begin work. That will be easy to understand where is problem.
