Complex profile - lines won't connect propertly on floor plan
Anatatj
I made complex profile for my fundation. In 3d view is ok, but in floor plan is not, for some reason lines won't connect propertly. If i change junction order in wall setting it does not help. Any tip?
Profile:
Plan view:
changing junction order:
3d:
Than you!
Try checking the strength of the building materials you have used for the wills.
The main part of the wall needs to be the strongest, so they always connect.
The outer skins need to be weaker.
Guru
You could try putting faux layers on the outside that match the materials of the inside. PBI will wrap them instead of terminating them then. This works for Composites, though it prevents Surface Override of the relevant face, but I am not sure if it would work for Complex Profiles.
AC22-28 AUS 3001Help Those Help You - Add a Signature
Thank you, that worked!
Setup info provided by author
