Complex profile section through window without lines
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-06-09
12:52 PM
- last edited on
2023-05-24
08:12 AM
by
Rubia Torres
2019-06-09
12:52 PM
When a section is made through a window in a wall that is made as a complex profile, no lines are displayed above and below the window.
Does anyone have a solution to this problem, and if not, that bug should be repaired.
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-06-10 02:54 AM
2019-06-10
02:54 AM
In the Profile Manager, select the fills used in the composite and be sure that you have 'Show Cut End Lines' active.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-06-10 11:41 AM
2019-06-10
11:41 AM
Thanks! I don't know how I didn't see that.
There is another issue. How to change wall closure on windows upper side? I know how to change left and right side, but can't find for upper side.
Maybe I should make another topic for this question?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-06-11 03:07 AM
2019-06-11
03:07 AM
Within your section? You cannot. It is a limitation of the software... Sections are generated from the 3D script of which there is not scripting for a top or bottom closure, while the for the plan, it is scripted in the 2D script.
Ling.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-06-11 02:42 PM
2019-06-11
02:42 PM
Ok, thanks! Maybe it should be considered for future versions of models.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-06-15 05:06 PM
2019-06-15
05:06 PM
Ling.
So, it is actually not a limitation of the software, because ARCHICAD could do it.
It is the limitation of the Library Part, which is not generating Reveals in 3D, only 2D.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-06-17 03:15 AM
2019-06-17
03:15 AM
Well, a limitation of most, if not all, of the default library parts.
