I have been using AC for some time now, mostly 16. And one question that comes to my mind when using it is: What is the point of having composit walls, and when am I supposed to use them? I mean, they are visually impressive when doing different kind of sections, and i Guess a Whole lot of other Things, but they serve no real use and purpose in my, although very Limited, use of AC.
Let me explain: I have been a carpenter for 17 years, thats what I do for a living. Using Archicad is mostly a hobby of mine. In all theese years , I've never ever seen a set of drawings that displays for instance the walls with all the layers that it really consist of. All the layers that together makes a Complete wall, is represented by an empty wall With the desired core thickness. I work With Residential homes, where the wall is either an internal wall or an exterior wall, so there really are no need for a detailed explanation of how the walls are constructed. But even on larger Projects, when they operate With many different composit walls, they are labelled With a certain id, and then you have to find a description of that ID in the Construction documents. And in these documents its likely to find a detailed drawing of the wall, like its done With a composit wall in AC
And even further, all the measurments on a set of Construction drawings are relativ to the core of the walls. Having a drawing that displays the wall even whith, for instance, gypsum Boards on it would only be confusing for the carpenter, and leave a lot of room for making errors.
If I'm to make a set of drawings for something, I prefer to use for instance Empty or simply Insulated wall as the wall type, set the thickness to whatever thickness the Complete core would have had in real life and then begin to Draw.
I have even tried to use "show core only" mode to Draw in, but that looked all weird, due to Natural reasons, the core wouldn't Connect properly..
Am I missing something vital?
Looking forward to some educational Reading 🙂
(BTW, how come a lot of my Words are in Capital first letter?)
.Thag
Windows 10, Archicad 27,28 and 29
