2015-01-01 07:55 PM - last edited on 2023-05-24 08:54 AM by Rubia Torres
2015-01-02 05:02 AM
2015-01-02 03:29 PM
Link wrote:In the Composite Structures dialog box it is the check box and pen setting in the middle of the Edit Skin and Lines Structure panel.
It's set in your composite structure settings. Play around in there.
2015-01-02 04:07 PM
2015-01-02 04:49 PM
2015-01-02 09:40 PM
2015-01-02 09:48 PM
Link wrote:
They're two different things.
The skin contour pen (as described in the dialog) sets the lines that separate the skins.
The skin end line pen (which is not so obvious) sets the pen for both ends of the skin.
If you're ever unsure of what something does you can generally right click on it and select 'What's This?'.
Link.
2015-01-02 11:00 PM
