2003-12-03
10:00 PM
2023-05-23
03:45 PM
Rubia Torres
2003-12-03 10:01 PM
2003-12-03 10:25 PM
2003-12-03 11:21 PM
If the reference line is on the out side of the cavity wall it is impossible for the stud wall to even touch the reference line of the cavity.This is the main reason that I put the reference line on the inside face of exterior walls. I know this is not a common practice (the only others I know who do this are people I have taught) but I have found over the years that it eliminates more trouble than it causes. The biggest problem I have had with this approach was on one project that changed from 2x4 to 2x6 exterior walls in late DD. Otherwise it has saved me lots of patching and fussing with wall intersections.
2003-12-03 11:32 PM
Matthew wrote:I switched to ArchiCAD when 8 came out and started by modeling my house. I discovered the advantage of having the ref line on the inside right away.
Are there others out there doing this too?
2003-12-03 11:35 PM
2003-12-03 11:39 PM
2003-12-04 12:14 AM
2003-12-04 12:42 AM
Geoff wrote:Well said, Geoff.
Here's what I'd like to see.
2003-12-04 07:10 AM
I've used recently another technique that has proven to be the right one in my projects : the ref line is the outer limit of my inner load bearing composite's skin : this allows to change the type of external finish easily, and adapt the width of the load bearing part depending of the Z position of the wall (wider cocnrete blocks in the basement, etc...)Surely this is the only way to go? I've never had trouble sticking to this method 100% of the time, and can't really see how you can go wrong using this with carefully constructed composites. If a wall changes composites/thickness, all walls will still heal because the reference lines never move.
