2019-09-23
10:52 PM
2023-05-23
06:00 PM
Rubia Torres
2019-09-23 11:19 PM
2019-09-24 01:31 AM
rjwilden wrote:That's what I was thinking as well. After digging through the parameters of my rail for almost an hour, I figured morph might be the best option. It will just be a bit time consuming.
Morph is possibly your best method. Very difficult to get it to work by adjusting the parameters
2019-09-24 01:52 AM
2019-09-24 03:13 AM
2019-09-24 06:42 AM
2019-09-25 01:39 AM
Lingwisyer wrote:Thanks Ling, that is a very good idea. I will give it a try.
There is not really a need to convert it to a morph. Edit the segment instead? In the lower segment, you can just turn off the balusters and change the fixing type.
In that was it stays associated to your stairs and if you need to change anything, you can reset the rail rather than redraw it.
Ling.
