Connecting beams on angles
Gidday fellas
I was just wondering if there was a solution to my problem...basically I have 2 beams joining together but they are not at 90 degrees to eachother...is there a way to adjust a section of the column so it fits snug? ***LOOK AT PICTURE*** I hope it works!
Nuggy
11 REPLIES 11
Nuggy,
I am assuming the reference line for the beam is in the center. It should join up if you stretch the center line of the one beam to the center line of the other one.
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
Gerald wrote:
Nuggy,
Not if the beam is an object which this appears to be.
If it is an object there may be a parameter to angle the end.
If no parameter then you will need to learn a little GDL to add the feature yourself.
Or hunt around to find a new object that does have end angles.
__archiben
they're objects, so this won't work at all
you need to turn on the 'cutting planes' in the object's parameters settings. it's a bit fiddly to start, but once you get the hang of it you can build well behaved steel structures quite quickly . . .
HTH
~/archiben
b e n _ f r o s t
Thanks, fellas
First things first...it is NOT AN OBJECT... lol JUST JOKING... yeah it's an object... I think I was using a UB out of AC9...I've got the Australian Essential addon and found a UB in there where you can do all sorts of goodies to it...thanks again, Ben... I just changed beams and it's all good... here's the proper solution.
Thanks for your help everyone.
Andrew
Here it is!
Thanks Barry...in the new beam I am using it has two "end cut" functions..one for one end.....and yep you guessed...one for the other!
Andrew
Djordje
Just to make sure ... the centerlines of both the beams should intersect at the column center, right?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
__archiben
why? we have to give engineers some ammunition, right?
~/archiben
b e n _ f r o s t
Djordje
No we don't ...
They invent enough anyway.
Djordje
HP Omen
