Connecting walls / window opening
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-07-22 02:16 AM
Hi, can someone help me with this please?
I made an example to "illustrate" the problem. If you look at the screenshot, there's wall 1 and wall 2. Wall 2 is hosting a window - an opening for the window is cut automatically.
Now, if I move the window into wall 1, the window does not cut wall 1.
In Revit, if 2 different walls are connected, joined or embedded into each other, the window recognizes them as 1 and automatically cuts it. Here's a screenshot of the same situation I made in Revit. What is the best solution to achieve this in Archicad?
- Labels:
Connections
Openings
Walls
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-07-24 03:21 AM
Unless something has changed, you should not need to stretch anything, the created Opening from Selection should match the size of your opening and automatically cut the bounding walls.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-07-24 03:41 AM - edited 2023-07-24 04:07 AM
Good to know what’s happening with this try. I will keep that in mind. Thanks for the feedback.
Edit: There should be a way to join these two walls at the junction so that Archicad sees it as one wall although made up of two different sections ? Then you can place an opening (window or door) that spans the two different parts of the wall.
24C GPU 7.8TF 32GB RAM OS Sequoia
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-07-24 04:49 AM - edited 2023-07-24 04:51 AM
If I use the"opening" tool, it just cuts a hole in the wall. But it doesn't "wrap" the internal finish skin. If you understand what I mean.
An "empty" window does wrap the skins. (See screenshots).
Oh well... Archicad has it's limitations I guess 😛
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-07-24 05:28 AM - edited 2023-07-24 05:28 AM
You can adjust the opening to peneteate any skins you like and change the perimeter surface to be as the external skin (Reveal), that will let you avoid error & duplication in windows schedule.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-07-24 10:48 AM
Aaanyway, back to this Wish, possibly related to the Door & Window listing on the roadmap.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-07-24 11:37 AM
Do they actually listen to these "wishes"? I mean, howmany of those have acually come true? xd
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-07-25 03:26 AM
There is that... it is also impossible to track any of them, some of them which are for major shortfalls that are still unresolved after many years... I am optimistically hopeful that this one is related to the Door and Window listing on the roadmap.
Ling.
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
