Consistency checking error
Tom Krowka
Got a new message today....when trying to save. Dialogue box comes up, says there is a missing part. "Conistency checking error" at the top of the dialogue box. Does not say what the missing part is however. Then I get three choices:
Continue working as is and work without saving,.
Save and lose items in questions
force Quit without saving.
Don't know which to do. Had a problem opening it, and had to use the .bpn, which opened. Any way to find the bad part, or fix, or something before I get $##*ed? Have been continuing working, but am going to have to save at some point.
Am using V11, with most current hotfix. This project was started in V8, used Architerra on it, has been migrated through the versions. Am not suprised it is not cooperative.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
4 REPLIES 4
I've had that before - so have some of my colleagues. If you don't save, it seems to get worse, and each future save has more and more unknown elements deleted. Then it gets to the point where you can't save at all because the error message keeps popping up till you say don't save.
Here was my trouble with it.
Anyway - my advice is to go to your last bpn (hopefully you haven't saved yet) and copy it somewhere else and give it a new name. This was your last uncorrupted version of the file.
Then, save your current file if you've done a lot since the bpn.
Open a new and reset project from your template and do a forward merge. You'll lose all your 2D info pasted into section/elev/detail windows (as mentioned in the thread I linked) but you can get most of this back from your bpn (now saved under a different name). Depending on the size of the project, you may lose a couple of days to sort all this out - but I still think it's better than losing the entire project due to some unknown corruption.
Good luck!
Tom Krowka
So it seems there is no real solution. Just forward merge, lose incredible amounts of time, and do it over. What a load of #####. Am losing the faith as far as GS is concerned.
Seems like the forward merge should be constructed so that all the 2d is not lost. Now that would be a nice fix.
Thomas@wkarchwk.com
www.walshkrowka.com
Eduardo Rolon
Tom I wrote this tip some time ago so I don't know if it is still valid but you can give it a try…
archicad-talk.graphisoft.com/viewtopic.php?p=20721&highlight=forward+merge#20721
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Tom Krowka
Thanks for the heads up. Am not real familiar with everything you referenced, but I might need to give it a try.
Thomas@wkarchwk.com
www.walshkrowka.com
