We value your input!
Contours in Complex Profiles
fuzzytnth3
I'm trying to suss out how you get contour lines to show in the 2d Plan window when using a Complex Profile.
The default Complex Profiles seem to do what I want but I can't find what it is that tells Archicad to show a particular contour line.
TIA
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
TomWaltz
Anything below the cut plane is shown as long as the wall is set to "Projected" or "Projected with Overhead."
Tom Waltz
fuzzytnth3
Thanks Tom that did the trick
Link
There is no setting for the uncut line type. You are stuck with continuous lines for anything that is projected.
Link.
