Convert solid morph to surface morph
Dontknow
I've seen several YouTube video's to convert solid morphs into surface morphs.
But when I select a face or edge of a morph and select delete the whole morph gets deleted and doesn't turn into a surface morph.
Also when I use 'Suspend Groups'.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
5 REPLIES 5
fuzzytnth3
I think what you mean is being able to select a face and then modify it or delete it. To do that hold down the Shift and Ctrl keys when clicking on the face or edge
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Dontknow
Yep, that did the trick.
They forgot to tell that in the video's.
Thnx for the info.
ArchiCAD 25.
Or in the selection tool settings you can change it from the black to white (sub-element) cursor.
Just don't forget to change it back when you want to select normal (whole) elements.
The CTRL+SHIFT toggle is a temporary swap to either cursor depending which one you have active.
Thnx for the info.
One short clip cannot contain all info because it would be very long.
You should also watch other clips:
https://www.youtube.com/watch?v=JBVLLjDJsDk
https://www.youtube.com/watch?v=FrIqtFHwz68
Dontknow
laszlonagy wrote:
One short clip cannot contain all info because it would be very long. You should also watch other clips:
Video's not video.
And they were not short.
ArchiCAD 25.
