2010-11-12
01:01 PM
2023-05-23
04:47 PM
Rubia Torres
2010-11-12 02:18 PM
2010-11-12 04:38 PM
Hayley_D wrote:I suppose by "converting" you mean you activate the 3D Window to generate the 3D model.
When trying to convert to 3D, it can take up to 20 mins.
When performing an object inventory, AC13 could take up to 30 mins.
Is there a solution to this problem at all?
Please help as it is extremely frustrating.
Thanks,
Hayley
2010-11-13 05:59 AM
2010-11-13 02:12 PM
2010-11-13 03:52 PM
Hayley_D wrote:Assuming you are not presenting the live 3D model and only need renderings you can use the trick Laszlo mentioned of filtering the 3D for walls, slabs and roofs or use layers to hide the complex parts while you set up the 3D views based on the simple massing. Once you have them all worked out you can create a publisher set to render the final images while you sleep (or whatever).
...I need the whole model when presenting to class - do you know of any way to speed the process up, ie, to generate the 3d image
2011-04-04 11:16 AM
