2004-06-03 12:52 AM - last edited on 2023-05-26 11:46 AM by Rubia Torres
2004-06-03 02:10 AM
2004-06-03 02:44 AM
Matthew wrote:Thank you for the tip, but what I am really trying to do is to have a tall door to go across the story by coping the wall (and the door) to 2nd story, explode the door to have the 2d representation on 2d floor plan, also now I can see the door cut through the 2nd floor wall in 3d. The problem is that since I can not locate the door below the bottom of the wall at second floor, the hole ends up too tall. I hope I am clear. Any thoughts?
option/alt click to pick up door or window settings, and place the door or window in the current story walls using the hotspots below as guides.
2004-06-03 02:59 AM
