ā2019-09-25
12:23 PM
ā2023-05-24
08:10 AM
Rubia Torres
ā2019-09-30 04:58 AM
ā2019-09-30 12:23 PM
ā2023-03-29 04:25 PM
Hello. The issue is how to connect the 2 columns to form a L shape column in the corner of the building (as there is no free form design method for column - there should be. The Multi segment column to my understanding cannot solve this. It is for connecting different profiles of the column the one above the other, not 2 side by side.
So, how is this done? Having 2 column is not the correct way.
Archicad 26
ā2023-03-30 03:38 AM
By using the Complex Profile Manager, you can make a column that has any shape and number of materials that you want.
Solution given in your other post (there is no need to ask the same question in multiple posts).
