2004-02-17 09:07 PM
2004-02-19 04:52 AM
2004-02-28 10:15 PM
Rashid wrote:thanks. 'preciate it. now how do these damn emoticons work
Excellent alternative solution Bill...
2004-02-28 10:24 PM
bill wrote:in case you're wondering censored was 'd a m n'Rashid wrote:thanks. 'preciate it. now how do these <b>[censored]</b> emoticons work
i'll try again
2007-02-09 12:23 AM
Archimac wrote:is there any good news regarding corner boards and ac v10? still no object as far as i can see. there are quoin corners in the masonry > wall extras folder and the d3 library has a similar 'trim quoin' in its trim > moulding library.
I am wondering how to attach wood corner trim to houses with wood siding. I want them to show up in the elevations automatically. Also, what about brick quoins a the corners. Any traditional residential master out there?
Thanks,
Stan
2007-02-09 12:32 AM
2007-02-09 12:59 AM
2007-02-09 07:42 AM
aahatimo wrote:Cadimage's Accessory Tool has one. Perhaps someone who uses it can say if it's worth the price. Anyone??
is there a corner trim object included in ac10?
2007-02-09 07:46 AM
2007-02-09 09:31 AM
2007-02-09 10:22 AM
Matthew wrote:Workarounds are not the optimal thing to do if you are using the same corner every time, then a GDL objekt is the right way to go in my opinion.
The various "workarounds" are not so difficult. I've used walls, slabs and custom parts (very simple ones) all to good effect and with out much trouble. Rusticated quoins are another matter though...
