2021-10-29 09:24 PM
i think it's a strange behaviour from Archicad as i remember i did this before correctly,
Placing corner windows on 2 diffentent walls causes problems in the corner frame, it won't connect even when i check " different wall thickness " and i add the thickness
Any soltion please ?
2021-10-29 09:59 PM - edited 2021-10-29 10:21 PM
it seems to work for me in 25 as expected.
try the other Corner ?
Also, both Window and Walls can be set to Projected instead of Symbolic - ?
2021-10-29 10:33 PM
Thanks steve for the reply,
It works for walls with the same thickness, but not with different wall thicknesses, Archicad 23
2021-10-29 11:07 PM
Like this - but does not work with 23. I got it.
2021-10-29 11:45 PM
Does this was mentioned in the new features of Archicad 25?
2021-10-29 11:47 PM - edited 2021-10-30 01:03 AM
It works for me in 23 as well.
It could be that his happens with a certain window type.
Something is not quite right. I have been able to generate the anomies a couple of times but I didn't notice it time to find what it was using Ctrl-z. What window are you using ?
I was able to get it to look correct using some the Bring To Front tool and changed settings to Projected rather than Symbol. I think it has more to do with getting things to rebuild than the settings changes ?
2021-10-30 12:05 AM
I glt it,
It works only when reveal is set to 0, then, i should place my windows on the inner face,
2021-11-01 02:28 AM
https://community.graphisoft.com/t5/Wishes-forum/Corner-Window-Differing-Reveal-Depth/m-p/296199
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
