Cover sheet ghost image 3D
Tom Krowka
I'd like to put a 3D line drawing of the project on the cover sheet. I would like it to be light, sort of like the ghost image. Anybody have a quick and easy way to do this?
Thanks
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
6 REPLIES 6
Petros Ioannou
Goto Window/3d window-use the internal 3d engine to view your model. Then save this view as PMK (plotmaker)-Edges only
Import the drawing in the plotmaker sheet and from its settings choose Attribute update rules/custom pens and colors.
Edit pens from the attributes and select all pens.
Give them a grey color.
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Djordje
Petros gave you very good advice.
The other option is to do a sketch rendering, with the light pen color. In this case, you have the image, not a vectorial PMK, so watch the size!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Tom Krowka
Thanks for the tip. World wide help, it's great.
Thomas@wkarchwk.com
www.walshkrowka.com
Tom Krowka
I tried your plan with the internal engine in the 3d window. I am unable to complete the generation of the window. I let it run about 10 minutes.
(internal engine to view the model) I've tried hidden line, and shading selection both. The hidden line crashed, shading runs on and on. Process is running at 95% CPU usage. Is there some other setting that should be off to make the generation simpler?
Thanks
Thomas@wkarchwk.com
www.walshkrowka.com
Petros Ioannou
Check that vectorial shadows are off (mage/3D window settings)-
Also try to make your model "lighter"-By turning off layers that don't appear in your scene (probably furniture if you are viewing an exterior etc)
10 minutes is quite a lot
Petros
32 GB 2400 MHz DDR4
Tom Krowka
That did the trick.
Thomas@wkarchwk.com
www.walshkrowka.com
