2012-03-23 09:28 PM
2012-03-23 09:46 PM
2012-03-23 10:45 PM
2012-03-25 12:24 AM
JaredBanks wrote:Thanks, this seems on the right track. Just how do I 'explode' whilst in 3D Document view?
Not sure why you'd need to go into AutoCAD... but if you are in a newer version of ArchiCAD (13 and up?) you make make a 3D document of any 3d view. That view can be exploded in archicad and turned into line work for the editing you'd do in AutoCAD.
Or conversely you could just do a save as DWG from the 3D document window.
Next week or the week after I'll have a blog post up that uses a similar process to take linework into Illustrator.
2012-06-05 03:43 AM
2012-06-05 05:24 AM
2012-06-05 05:42 AM
Barry wrote:Yes, I'm aware of that. What I'm unclear on is how to save out as a DWG. Don't ask why I need to do that. It's just part of the artist's workflow.
You can save from the 3D window directly as a Piranesi (.EPX) file.
2012-06-05 01:27 PM
2012-06-05 06:58 PM
sboydturner wrote:One would think that to be the case, but give it a try. What you get is a DWG of the floor plan.
Dave,
To save 3D *.dwg file open 3d window and do a save as with the window at the front and select dwg as the file format, 3d dwg saved.
2012-06-05 07:59 PM
