Roopa A
Create Lion and Cow face
Hai,
I need to create face of lion and cow, I tried with morph, I am not getting it properly as I want.
I searched for object also, I dint get it.
Please any one help me in this.
I have attached the image how it is to be . The sectional view of that.
Thank you.
Roopa A
Roopa A S
37 Replies 37
Roopa A
I checked in this.
And even in Thingiverse, Archibase planet, Archieve3d.net.
I dint got the I want,
Atleast similar also dint got.
Roopa A S
vistasp
Ah, well, then you have no choice but to model it yourself.
Hope it works out for you.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Roopa A
I have created with morph.
How to make it as solid or to look like solid??
Here is the image attached.
Is it is ok? Or need to do some corrections!
Suggestions please.
How to make it still realistic??
Roopa A S
Erwin Edel
If you have access to the actual sculptures: https://forums.sketchup.com/t/awesome-3d-scan-app-0/118404
That might be a quick solution for you.
The one time I had to do a sculpture, I just went for 'boxing' it out with basic shapes and described that actual sculpture in the contract documents. No-one in their right mind was going to pay me for that amount of hours of trying to model something that some factory just has lying on the shelf (they won't reference my drawings) or if it is existing already, even less reason to model it accurately. Just my (im)polite opinion 😉
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Roopa A
Please can anyone help me in this. I want realistic model of this. Not getting in the proper way
Here is the view attached.
Roopa A S
Nader Belal
Mentor
@Roopa
Right now you have catched my intrest ... and I would like to see how it can be done.
On another side, I would try to download a nice 3D model head for those animals, and make sure that they can be manipulated in Rhino, Why ??
So that you can use the Grasshopper ArchiCAD connection to make those time consuming adjustments easily and quickly, and send the data to ArchiCAD as Morphs ... unless you need something really specific which in this case you will need a 3D sculpture artist, that can export his work to a file exchange format compatible with ArchiCAD.
Out of curiosity, does you requirements have something to do with Minoan or Hindu architecture ??
Roopa A
Moonlight wrote:
@Roopa
Ok...
Ok thank you,.
I searched in websites which I know. But I dint got the result..
I dont have Grasshopper..
Hindu architecture.
Roopa A S
Roopa A
I downloaded from archibase.com. Here is the link.
https://archibase.co/download/ce7e3456.html
https://archibase.co/download/21576988.html
Now I need to edit that model. I converted into morph. I need to open the mouth of the animal from that we have a step. How to do that??
I splited the model. Next how to edit??
Roopa A S
That is the bit you will find is rather difficult.
Archicad is really not very good at this sort of modelling.
I would split the head so you have a top and bottom jaw.
Then split vertically where you want the bottom jaw to pivot.
You might want to place a temporary roof/slab/wall to get the cutting plane easily.
Now I would rotate the bottom jaw down.
Now the hard bit will be adding surfaces to join up the gaps.
Then union all the pieces back into one morph.
Add slabs,beams to form the passage you need and then SEO that from the morph.
I am sure it is much easier said than done.
Hmooslechner
I would mould it in clay in the way i want it and then i would make an 3D-Scan. (or let mould it by an artist i trust and 3D-Scan it.) This is artwork - nor architectural work.
