Create a Roof
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2018-01-21
01:24 AM
ā2023-05-23
02:14 PM
Rubia Torres
Please explain me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-01-21 02:17 PM
smhbrv wrote:Please help me.
Hi. How can we create this roof ? Is there any way to create it.
Please explain me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-01-21 02:25 PM
Create each roof plane with the desired slope and direction using the Single-plane Roof geometry option. Then connect the planes using the intersect command. In the Help files see: Elements of the Virtual Building > Construction Elements > Roofs > Editing Roofs > Intersect Single-plane Roofs.
www.davidmaudlin.com
Digital Architecture
AC28 USA ⢠Mac mini M4 Pro OSX15 | 64 gb ram ⢠MacBook Pro M3 Pro | 36 gb ram OSX14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-01-21 02:45 PM
David wrote:Thank you for your help. I try this but I dont create this model.
smhbrv:
Can you create this model with a video. ? I dont find a formula "how can i do this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-01-21 05:02 PM
smhbrv wrote:Help me please.David wrote:Thank you for your help. I try this but I dont create this model.
smhbrv:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-01-21 06:07 PM
Take a look at the you tube channel for Archicad.
look for videos on the roof tool.
https://www.youtube.com/watch?v=tO7W-T6T0JU
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-01-23 07:07 AM
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-01-23 08:30 AM
Model 3 columns for the 3 apex heights for the first roof section.
Use a zero thickness polygon single roof plane and click on points 1, 2 & 3 to define the roof slope.
Then click points 1, 2, 3 and 1 again to define the shape of the roof surface.
Now do the same for 4, 5 and 6 - once to define the roof pitch and again to define the shape of the roof surface (click points 4, 5, 6, and 4 again to define the surface).
I used guidelines to get the position of point 4 but you could place another column.
Now you have these 2 planes, you can mirror copies to get the rest.
Now if you want you can select them all ad add a thickness.
For some reason it does not work well if you set the thickness before defining the roofs.
Edits in red
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-01-23 10:26 PM
Barry wrote:Thank you for your help. But its too hard for me
It is quite easy to do in 3D.
Then click points 1, 2 and 3 again to define the shape of the roof surface.
Now do the same for 4, 5 and 6 - once to define the roof pitch and again to define the shape of the roof surface.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-01-24 01:59 AM
smhbrv wrote:I can try but I will have to do it a little later.
Thank you for your help. But its too hard for meCan you explain this with a video please ?
It really won't tell you any more than explained.
Each of your roof planes have 3 points.
You need to establish the heights of these points in 3D - hence the columns.
Now all you do is set the roof tool as shown in the image and click on the first 3 points (top centre of the columns) to determine the roof plane slope.
Click the same 3 points again to place the roof plane.
Do the same for the next 3 points (4, 5 & 6).
Now you have all you need - just a matter of mirroring copies to get the complete roof.
I will look at making a video later today, unless you solve it in the mean time.
Or somebody else beats me to it.
