2018-01-21
01:24 AM
2023-05-23
02:14 PM
Rubia Torres
2018-01-21 02:17 PM
smhbrv wrote:Please help me.
Hi. How can we create this roof ? Is there any way to create it.
Please explain me.
2018-01-21 02:25 PM
2018-01-21 02:45 PM
David wrote:Thank you for your help. I try this but I dont create this model.
smhbrv:
Create each roof plane with the desired slope and direction using the Single-plane Roof geometry option. Then connect the planes using the intersect command. In the Help files see: Elements of the Virtual Building > Construction Elements > Roofs > Editing Roofs > Intersect Single-plane Roofs.
David
2018-01-21 05:02 PM
smhbrv wrote:Help me please.David wrote:Thank you for your help. I try this but I dont create this model.
smhbrv:
David
Can you create this model with a video. ? I dont find a formula "how can i do this.
2018-01-21 06:07 PM
2018-01-23 07:07 AM
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2018-01-23 08:30 AM
2018-01-23 10:26 PM
Barry wrote:Thank you for your help. But its too hard for me
It is quite easy to do in 3D.
Model 3 columns for the 3 apex heights for the first roof section.
Use a zero thickness polygon single roof plane and click on points 1, 2 & 3 to define the roof slope.
Then click points 1, 2 and 3 again to define the shape of the roof surface.
Now do the same for 4, 5 and 6 - once to define the roof pitch and again to define the shape of the roof surface.
I used guidelines to get the position of point 4 but you could place another column.
Now you have these 2 planes, you can mirror copies to get the rest.
Now if you want you can select them all ad add a thickness.
For some reason it does not work well if you set the thickness before defining the roofs.
2018-01-24 01:59 AM
smhbrv wrote:I can try but I will have to do it a little later.
Thank you for your help. But its too hard for meCan you explain this with a video please ?
