Creating a curved roof?
I need to create a roof that is curved, arched, however you want to put it. Anyone know how?
11 Replies 11
Dwight
In view of the smoothness and instant editing of the complex profile, is the roof tool approach valid now? Especially since the arc can never go negative and the complex profile can go anywhere?
Are there any advantages to the roof for this geometry?
And all words come from the Greek.
Dwight Atkinson
Creating a curved roof is fairly easy, but what I'm missing is what kind of curved roof? Is this a dome or just an arc extruded in a straight line? Does it need to be perfectly smooth, or can you tolerate visible segments?
If it's a dome that can tolerate visible segments, there's a link that was posted that covers it, http://www.graphisoft.com/archiguide_archive/ArchiGuide_Online_6o/issue15/roofs.html
For all the others, the simplest way to do it is to use a complex profile, as has been suggested. It took me a little while to get used to the complex profile, but just need to keep a few things in mind about it. First, the design in the complex profile is the section view, and will be extruded either vertically (columns) or horizontally (wall/beam). Secondly, the section needs to be a fill, and you set the material properties of that fill.
Visit the other posted link, http://www.archicadwiki.com/Creative%20Uses%20of%20Complex%20Profiles, for a more in depth coverage of the complex profile tool.
In case you haven't been able to find where the complex profile editor is stored, it's in the Options --> Element Attributes --> Profile Manager
Hope it helps.
Adeel
