‎2017-07-10
09:57 AM
‎2023-05-24
08:29 AM
Rubia Torres
‎2017-07-10 11:07 AM
‎2017-07-10 11:59 AM
‎2017-07-10 03:54 PM
‎2017-07-10 04:28 PM
‎2017-07-10 05:10 PM
‎2017-07-11 09:46 AM
‎2017-07-11 10:18 AM
thompsonmp wrote:Yes that is the correct default location - I have a customised Work Environment and I still have it where it used to be in old versions.
Thanks.
As i had the walls above one another I tried the Merge Walls option but I could only find it under the following:-
Edit>Reshape>Merge Walls
thompsonmp wrote:Possibly just turning off the surface overrides in the wall settings will fix it.
I selected both walls, merged them using the above but the whole wall has now gone dark grey (the top was light grey and the bottom brick/brick coloured)
How do I control the hatch/fill in elevation please?
‎2017-07-11 10:31 AM
thompsonmp wrote:They would need to remain separate - I don't think you could merge them even if you try.
How would it work for a curtain wall with masonry at low level? Can the two be merged or do they have to be separate?
‎2017-07-11 10:41 AM
