2023-12-29 04:43 PM
2023-12-29 06:36 PM
Probably used override surfaces under model attributes of the door in the curtainwall settings?
2023-12-30 02:57 PM
filhalbate:
To illustrate Cuba's point, make sure this is not checked.
If the panel is not visible in your dialog box, then see this similar tip for showing it: Easily control the material of Door surfaces.
David
