‎2013-03-02
09:36 PM
‎2023-05-24
12:49 PM
Rubia Torres
‎2013-03-03 01:08 PM
‎2013-03-03 03:45 PM
Frame IntersectionsSo I don't think the default settings can be changed.
When two Frames meet in a Curtain Wall, the Frame with the higher priority will cut the other one.
Frame Priorities are predefined for each Frame class in Curtain Wall Settings.
These values are not editable at the level of Frame classes. The slider shows the intersection levels of the built-in Frames (left to right: Transom - 5; Mullion - 10; Boundary - 15).
However, you can change the intersection priority of any single selected Frame. In Curtain Wall Edit mode, select the Frame whose intersection priority you want to change.
rocorona wrote:Possible only once the Curtain Wall is placed. These Find & Select options are available only after entering Edit mode.
Use the "Find & Select" command to search the frames by class.
‎2013-03-03 08:16 PM
Possible only once the Curtain Wall is placed.Yes. I was referring to the image from Jere, where the Curtain Wall IS in editing mode, but frames are not selected. (He was complaining about doing the priority adjustment one frame at a time.)
‎2013-03-04 12:26 PM
‎2013-03-09 09:24 PM
‎2013-03-10 09:09 AM
laszlonagy wrote:
Maybe the easiest solution would be to rotate the Curtain Wall in its vertical plane 90 degrees after placement
