Curtain Wall problem (AC18)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-08-23
11:29 PM
2023-05-24
08:57 AM
Rubia Torres
I have tried rebuilding, refresh, saving and loading the program, looking for filters, hidden layers and nothing seems to work,
I will appreciate hearing for some other users experiencing problems with Curtain Walls. I never had these problems with earlier versions.
Thanks in advance for your help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-08-23 11:53 PM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-08-24 01:56 AM
Unfortunately, it is not that. I failed to mention that in the next bay (adjacent space between columns) I have sections of curtain walls that show both in plan, section, 3D, etc
That's not all, in another location, I have a scheme exactly the same, have check the settings over and over and the wall "draws" with a height different that the sum of the numerical entries.
I suspect that there are some obscure setting I have not encountered or there are serious problems in this file.
Saludos !!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-08-24 03:04 PM
Try also looking at the Floor Plan and Section > Floor Plan Display area of the Curtain Walls Settings, and see if these match the settings of a visible Curtain Wall. I don't think there were any changes to the Curtain Wall in AC18.
David
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-08-24 09:20 PM
All my problems surface on Friday's; go figure.
I am waiting for Monday to call GS and see if I they would like to "see" what I am talking about.
The file is too big to e-mail so I'll try early to beat the Monday crowd.
If I learn something worth it, I will share it here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-08-25 02:38 PM
One last thought: is he CW assigned to the correct Home Story? If not, select the CW, right-click, and select the Relink Home Story... command.
David
Conrado wrote:Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-08-25 09:08 PM
Relink to Home story did fix the problem. Ugly, ugly, ugly !!
Cannot work from floor plan since the object disappears and cannot "pick" it.
Have to do it in 3D to visually see the effects.
I am glad is only a nine story building. What a pain.
Anyway, thanks for your insight, David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-08-26 03:02 AM
This was a huge issue when 17 came out.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-08-29 01:17 AM
I would also like to share the problem I had editing (modifying) the bottom edge of the Scheme perimeter.
While editing and clicking on this edge, you may be selecting another edge superimposed or the reference edge happens to match the location od the Scheme edge.
So check and place your reference edge a few inches away and if you do not see it while editing, try zooming on a lower corner of the scheme and orbiting the image and you will see two different lines: the reference and the bottom edge of the Scheme.
I hope this to be of help to another user(s)
