‎2016-04-18
08:26 AM
‎2023-05-24
08:41 AM
Rubia Torres
‎2016-04-18 01:34 PM
‎2016-04-18 03:32 PM
‎2016-04-18 05:19 PM
‎2016-04-18 05:25 PM
‎2021-06-29 08:57 PM
arqrivas wrote:To me, this is the simplest and best solution. I don't know about you all, but as soon as I start changing the intersection number, I start chasing my tail and get problems later. This is simple/ clean/ works well, thanks so much! Note, it is best/ easiest to change the layer intersection number through "Attribute Manager" so that you can change it for all of the view layer combinations at the same time.
Hi, I had a problem like this before, I solved with the layers intersections priority number. You could try that also. Make a different layer for each wall and make each one with different intersection number. Also if possible I would use the beam tool to make the complex profile (not sure if that will work but I'll try it)
‎2021-06-29 09:02 PM
lukegolesh wrote:It has already been alluded to, but what I meant to say was that changing the *"junction order" is problematic, but grouping each floor's walls on a layer and then changing the layer intersection number to be different from each other works well. (And best to do this through Attribute Manager).
‎2021-06-29 11:28 PM
‎2021-06-30 10:10 AM
