ā2006-06-19 05:06 PM
ā2006-06-21 02:24 AM
Intersection angle had no effect.Tom,
Reference lines moved all over, no effect.
They are the same profiles.
Tried the same thing with skin priorities on and off, with no effect.
It is 100% reproducible with every custom profile we have tried, including those from GS. We have not had one profiled wall clean up in 3D yet.
ā2006-06-21 06:48 AM
ā2006-06-21 03:07 PM
ā2006-06-21 04:10 PM
ā2006-06-21 04:13 PM
another Moderator
ā2006-06-21 04:19 PM
ā2006-06-21 04:23 PM
ejrolon wrote:What's really funny is that wall was part of the template from Graphisoft.... Still, I would have expected the profile engine to be a little more robust!
Found the possible problem:
In your custom profile the fills nodes have mistakes. There are overlaping fills, extra nodes and holes between fills. I captured your profile and fixed the fills and it is now cleaning up correctly.
ā2006-06-21 04:48 PM
another Moderator
ā2006-06-21 05:03 PM
ejrolon wrote:Nor enter a building that you did not build with your own hands.
Doors and Windows are behaving correctly. I had to do a merge of your file because I was getting errors on a wa_trim_us10.gsm everytime I inserted a window. I have no idea what it is. After the merge it worked fine.
note
Never trust anything that you have not drawn yourself
ā2006-06-21 11:29 PM
