‎2014-12-11
04:16 PM
‎2023-05-23
04:23 PM
Rubia Torres
‎2014-12-11 08:10 PM
‎2014-12-11 09:18 PM
Erich wrote:
I think your method is the one I would use. Are you having issue?
Is it just me or do those forms look like twin Winnebagos?
‎2014-12-12 12:54 AM
‎2014-12-12 02:23 AM
laszlonagy wrote:
Probably this is the best method. You could also use SEO to cut out that part of the Wall, but the result of the SEO would not be visible in 2D, so that would not be as good a solution.
‎2014-12-12 07:14 PM
rob2218 wrote:You'll need to get over that because it is a fundamental workflow in ArchiCAD and is much more flexible than creating windows, which need to be recreated and updated in your library if anything changes.
there's something about having "STUFF" be in an invisible layer just for the sake of "cutting shapes" in elements in the model that kinda doesn't agree with me.
‎2014-12-12 07:21 PM
