Achille Pavlidis
Custom frame profile with Curtain Walls
I have created a custom frame profile and saved it as a library part.
Although when I select it on the Curtain wall settings it appears correctly, then when it is placed it has nothing to do.
See attached images. Why is this happening?
Custom profile library partCustom profile library partCustom profile as corner frameCustom profile as corner frameCorner frame not the one selectedCorner frame not the one selected
Operating system used: Mac Apple Silicon 13 Ventura
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
11 Replies 11
Vinicius Lima
Instead of the Modular Profile, try the Editable Glazing Profile. It should work better.
The Modular Profile should be used when you want to combine more then one frame peaces (more complex solutions)
- Vinícius Lima - user since Archicad 12
from Brazil
Apple MacBook Pro 16" 2023 | M2 Pro | 16Gb RAM | macOS Ventura 13.5.2
Achille Pavlidis
Guys thanks for all the suggestions
In the end it had to do with Projection settings.
Specifically Floor Plan & Section -> Floor Plan Display -> Projection Mode Hybrid -> Set display mode for visible components -> Cut Components -> Projected.
I think GS should somehow streamline how the custom frame profile works...
