‎2006-01-05
02:03 PM
‎2023-05-23
03:32 PM
Rubia Torres
‎2006-01-05 03:24 PM
‎2006-01-05 03:46 PM
‎2006-01-05 03:51 PM
‎2006-01-05 03:55 PM
miker wrote:View the wall in 3D. Activate roof tool, single plane. Click on the two bottom ends of the wall, and one top. That will make a transparent triangle - that is your roof plane. Now click on four points to define the roof plane. Done.
Yes i already using the solid element operations but what about if you want to cut a wall in a sloped level, from Right-bottom corner to Left-Top corner and create a triangular wall?I can't find any element to do that except the roof
Thanx
‎2006-01-05 08:58 PM
‎2006-01-05 09:06 PM
‎2006-01-05 09:30 PM
miker wrote:What's the difficulty that you are having with the roof tool? Just that you find it difficult? Or is it causing some other problem?
Is there any easier way to cut a wall other than a roof![]()
The roof tool is nice but i am never use roofs so when i want to cut a wall is hard for me to fit the roof on the precise position (length,angle)
Something like a cutplane
‎2006-01-06 12:31 AM
