DESIGN OPTION : Select all elements
Bdesign
Hello, I was wondering if it's possible to select all elements included in a design option? Considering there are a lot of elements, objects, etc in the option, it can take a while to select everything. Any tips?  Thanks!
Find & Select.
Or in the Design Options palette, set the option you want as default, and then turn on the option to 'Edit Default Only'.
Find & Select.
Bdesign
Amazing, I understand the design option tool much better now! Thank you!
Setup info provided by author
